I need to create a small circuit that runs a 12/24vdc diagram pump, attached pump curve. I want to run this circuit from say a 24v drill battery if possible. I have read up on some battery circuits but need some help and insight about building the circuit. I need a run time of 3-4hr min, says .3A max draw, so i calculated roughly 1.5AH battery.
I know you shouldnt discharge the battery below 20%. What is the best/easiest way to control this, is there something i can just wire inline or would the drill batterys have it integrated if i buy a certain model?
I also want to integrate the charger and be able to power the pump from 120vac as well. I can buy a 120vac to 24vdc power supply and have a switch to switch between 120vac or 24vdc battery source.
Would a 24vdc battery backup be a better choice for this circuit, since it would probably have everything already integrated?
