I have an 24V DC adapter and i need to get a +15V and -15V as my Vcc and Vss for my circuits. I have 7815 as well as 7915 voltage regulators. Can i know how can i obtain +15V and -15V by using the 24V DC adapter as the input?
If there is a common [0V] rail for the +15V & -15V rails then you can't do it. You need a DC source with at least 35V and then you also need a means of creating the required common rail. You could use two 24V DC adapter supplies however.
In some cases the negative supply is more or less a bias supply -- low current. If so a charge pump ( maybe even with a 555 timer ) can be a solution. Also note that computer supplies give + - 12 ( lower current on neg side ) and can be usefully adapted. Many hits on google and instructables.
i need to build a prototype for my project.. the +15V and -15V from 24VDC is just my Vcc and Vss to supply for my other IC in the circuit. Is there any simplest way to get a +15V and -15V from a single power supply 24VDC? i had tried using 7815 and 7915 from a single power supply 24VDC.. the problem is i can simulate it no problem in Proteus but when i testing in practical i cant get -15V from 7915.. any idea?
