240w Power Supply at 93.5% efficiency = 256w or 271w at wall?
EdHo
Joined Jun 10, 2016
10
I have a Meanwell HLG-240H-C2100B power supply (119v, 2.1a, CC, powered by 240v AC)
powering 3 Bridgelux Vero29 LEDin series. The output from the PS reads 115v, 2.1a = 241.5w.
Shouldn't the AC Watts "in" measure 258w? (241.5/.935=258)
I get a reading of 271w in - which suggests an efficiency of 89% not 93.5%.
Should I be checking the test equipment or is this difference to be expected?
mcgyvr
Joined Oct 15, 2009
5,394
93.5% is "typical" and based on a specific load.. Did you read the charts in the datasheet?
Specifically the "Efficiency vs load" chart on page 7
Not sure what you are using to measure output/input wattage either.. Could be accuracy issues there too,etc...
EdHo
Joined Jun 10, 2016
10
If I read it correctly, 100% load is 250w at 93.5% efficiency. Since this load is 241.5w, which is close to full load (96.6%).
According to the chart, efficiency shouldn't drop below 90% until load is below 35%. As far as "typical", I have checked 6 of these and they yield similar results +-2%.
I think you confirmed that I need to check the accuracy of the meters.
Thank you!
RichardO
Joined May 4, 2013
2,270
Does this mean that you are using two meters -- a volt meter and a current meter?
If so, you are also measuring the power factor since the voltrage and current are not going to be perfectly in phase. Even a power factor corrected power supply is going to have a less than 100% power factor.
AnalogKid
Joined Aug 1, 2013
11,055
The tolerance for an efficiency spec rarely is stated, and typically is 5-10%. Also, peak efficiency might be achievable only with a resistive load.
ak
EdHo
Joined Jun 10, 2016
10
A Fluke79 measures the dc output voltage and current. A separate in-line meter measures the AC input voltage and current. (Bayite AC 80-260V 20A).
AlbertHall
Joined Jun 4, 2014
12,347
The data I found on the Bayite meter didn't say whether it was measuring true RMS or not. However it did say " This module is only suitable for pure AC 50-60HZ the mains." which rather suggests it isn't <surprised>
EdHo
Joined Jun 10, 2016
10
I am not the sharpest tool in the outlet. I "thought" that my municipal power didn't need true rms to be measured correctly...
Is that not so?
AlbertHall
Joined Jun 4, 2014
12,347
Is that not so?
The voltage should be OK, but the current (input to SMPS) is unlikely to be pure sine.
[EDIT] What are the voltage and current readings from The Bayite?
EdHo
Joined Jun 10, 2016
10
Bayite numbers for 3 Power Supplies
247v - 3.39a - 811.9w
3 Power supplies output
#1 114v 2.077a = 236.77w
#2 113.5v 2.097a = 238w
#3 115v 2.1a = 241.5w
716.27w total
EdHo
Joined Jun 10, 2016
10
So do I need a true RMS meter for the AC going into the Constant Current power supply, the DC out, neither or both?
34,465
For the AC power you need a real power meter that compensates for the effect of the power factor, such as a the Kill A Watt meter.
Measuring the voltage and current separately, even with an RMS volt/amp meter and calculating the VA product, will give you the apparent power, not real power.
For DC power any DC meter will work since they all measure real (RMS) power.
