240Vac to 24Vac and 24 Vac to 24Vdc bridge
Tryin2learn
Joined Nov 11, 2016
102
Can some one please help me I am newbie so I am trying to go from 240vac to 24vdc . I was thinking a transformer from 240vac to 24vac then a bridge to 24dc only problem I only have a vague idea how to make one .could someone please take the time to tell me in detail please . Also is this the cheapest way of doing it ??. By the way it is to power a actuator thanks a lot Keith
Papabravo
Joined Feb 24, 2006
21,228
Hi Keith. A couple of things. AC voltage is measured using the RMS(Root Mean Square) technique. Ignore the details of why this is true for the moment. The peak value of an AC waveform which is measured with an RMS value is 1.414 times the RMS value. From 24 VAC this would be:
\(24 \times \sqrt {2} = 33.94 \; \text Volts\)
When you use a bridge rectifier on the 24VAC you'll get about 32.5 VDC out of that. This might be too much for your actuator.
AlbertHall
Joined Jun 4, 2014
12,347
Transformers are expensive. It would be cheaper and if it is switched mode, lighter and smaller to use a ready made wall wart (a plug-in power supply). It would also take care of the safety of the mains connection.
Tryin2learn
Joined Nov 11, 2016
102
Thanks better try something else
MaxHeadRoom
Joined Jul 18, 2013
28,702
@Tryin2learn. Capacitor is not needed on rectified AC for any inductive device. the x 1.414 does not apply.
So the output is OK for a 24vdc device with just the bridge.
Here in N.A. hardware stores sell a cheap transformer that does the job.
Max.
MaxHeadRoom
Joined Jul 18, 2013
28,702
Never seen a 18vdc transformer?;)
You will need 24vac secondary when using no capacitor, the 1.4 factor only comes in when capacitors are used.
This allows the use of the more common 24vac secondary.
Max.
mcgyvr
Joined Oct 15, 2009
5,394
Tryin2learn
Joined Nov 11, 2016
102
Hi'ya what I have been trying to do is when I switch my extractor on it switch's a actuator on on the outside wall to pull up a steel plate that is covering the extractor hole to keep draughts out ( we are living on top of a hill and it's surprising how much draught comes through a 12 inch hole ) the plate will lower when I switch the extractor off much like a sash window going up and down . The plan so far is to use a onrom LY2N_J dpdt relay the extractor is 24vdc so I was going to take the power from the fan motor Connexions on to ins 7-8 of the relay and loop them on to a PSU to drop the current down to 24 vdc to move the actuator up and down . I understand I will have to take the output from the PSU back to the wiper terminals 5-6 on the relay .OK so far ?? Then I connect the actuator to pins 1-4 to raise and lower the plate . Does everything done OK . One further question do you have to observe polarity on these relays ??. Thanks for your you
Tryin2learn
Joined Nov 11, 2016
102
Sorry can't make head nor tail of them drawings so positive of the fan terminal goes to no pin no 8 and negative to in 7 OK .what about 24 vdc coming from PSU I understand they go to the wipers pins 5-6 do I have to observe polarity ??
mcgyvr
Joined Oct 15, 2009
5,394
Specs on the actuator?
Does it have internal limit switches to stop its motion at the up and down points?
If not you are going to need to add limit switches also..
What you want to do is drop dead simple.. But we need info on the components you are using..
Then getting you a diagram of the whole thing is simple..
Tryin2learn
Joined Nov 11, 2016
102
Yeah all I am struggling with is the connections on the relay .Yes the actuator has limit switches and like I said 24 vdc
MaxHeadRoom
Joined Jul 18, 2013
28,702
I am assuming that the actuator is motorized? If so what is the rating of the motor?
The rating charts for the contact life and current capacity only cover DC resistive loads
Max.
Tryin2learn
Joined Nov 11, 2016
102
Hi'ya if this helps just looked at actuator details all it lists is lifting capacity etc . Then says no load current 1 amp load current max 3 amp .hope this helps Keith .
Max.
No idea max just says heavy duty linear motor high performance 75n 165lbs .
