24 volt inverter
Discussion in 'The Projects Forum' started by icghandi, Apr 13, 2011.
  1. icghandi
    Apr 13, 2011
    Good-day all,
    i consructed a 24v inverter using cd4047, and it worked fine but when i connect it to the main suppy the MOSFET (irf250) burns. this occurs during change over to mains power supply. i suspected a transcient factor and introduce snubber in output teminals but this only reduced the freqencies of MOSFET damage. what else can i do, this my 1st time of construting a 24v inverter, am used to the 12v type. pls help
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    If you are able to post a clearly labeled schematic diagram(s) of your circuit(s) then it will be much easier for forum members to make informed comments & suggestions.
  3. icghandi
    Apr 13, 2011
    thanks 4 ur response, i luv to post d cct diagram by how do i do it, am new to forum like this.
