Gentlemen:
I have an application question. This may not be the correct forum and I apologize in advance if that's the case.http://www.amazon.com/GEREE-1-Channel-Relay-Module-switch/dp/B00PS4H362
I wish to power a 24 vdc relay momentarily then have the device continue to supply 24vdc for another 10-20 seconds before opening the circuit.
The load is approximately 15 amps @ 24vdc. (an electric marine head)
I thought I had the solution with this relay (link below)
Sadly, it would only work with power applied continuously. This was a $9 item, so no great loss but frustrating.
My question: Is there a similar "off the shelf" option or possibly a simple (very simple) addition to this relay that would solve my problem?
Thanks,
Duncan
Thanks,
Duncan
