I have a 24 Volt DC supply that I am wanting to charge a 12 Volt battery. I have the PB137 battery Charging IC.
The Input voltage shows on the datasheet that the voltage max is 40 Volts yet on reviews I read that it should not be more than 18 Volts.
I am trying to find out if 18 Volts is in fact the max and if so what would be the best way to convert from 24 to 18 Volts to charge this battery
