24 V Automotive Electric Fan
Discussion in 'The Projects Forum' started by Lightfire, Nov 28, 2010.
  1. Lightfire
    Oct 5, 2010
    690
    21
    I went to mall earlier to find 12 V automotive electric fan. Yes I found one but its 24 V. Is 24 V automotive fan can be powered by a 12 V battery???:)
    Thanks!!!!!
  2. debjit625
    Apr 17, 2010
    790
    186
    A 24V automotive fan can be powered by two 12V batteries connected in series making a total 24V.With a singal battery it will not run properly.
    Good Luck
  3. iONic
    Nov 16, 2007
    1,422
    68
    Is bringing the fan back out of the question?
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you try to power a fan rated for 24v by a 12v automotive system, it will run very slowly.
    You really need to find one rated for 12v instead. You might have decent luck at a junkyard/the breakers' yard.
