24 to 12 volt circuits
Discussion in 'General Electronics Chat' started by MI Installs, Jul 26, 2007.
  1. MI Installs
    Jul 26, 2007
    Installing equipment on off road machinery that is 24 volts. I would like to get my power source from the ignition switch. The device only draws 50mA @ full power (12 Volts) and I have a limited amount of space to work with.:confused:
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    For 50 mA @ 12V you just might be able to use a 7812 in a TO-220 package. At 600 mW it will get just a bit warm.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    That should work OK - but you should also use some capacitors on the input and output to prevent oscillations, because it's a given that the wire length is going to be at least a foot either way. Use an 0.33 uF cap to ground on the input, and a 0.1 uF cap to ground on the output, both with a 30v rating. Otherwise, the oscillations could lead to some mighty high voltage spikes.
    A Texas Instruments uA7812C has a rated output of up to 1.5A (with proper heat sinking, of course) with a minimum Vin of 14.5 and max Vin of 30. If you get it too warm, it'll let you know by shutting down (thermal overload protection). A National LM7812 or other xx7812 would work just the same.
  4. MI Installs
    Jul 26, 2007
    Thanks for the responses
    Would it be possible to get a drawing of this circuit?
  5. John Luciani
    Apr 3, 2007
    477
    There are drawings in the LM7812 datasheet.
    (* jcl *)
