24/4 volt to 12 volt only
Discussion in 'The Projects Forum' started by bigjerm, Nov 18, 2014.
  1. bigjerm
    Nov 18, 2014
    i have a circuit with an output of 24v when active and 4v when in stand by. i need to power a 12v fan only when the circuit is in the 24v phase. how would i go about creating this additional circuit?
    if this has been covered before, please link me to the thread. i searched but couldn't find anything similar.
  2. wayneh
    Sep 9, 2010
    12,374
    3,226
    You could use a 5V zener followed by a transistor switch (to control the fan). This would handle the shutoff at 4V. You could use a 12V regulator to drop the voltage from 24 to 12V.
    Actually you could probably just use the 12V regulator. When it sees a 4V input, the output won't be enough to run the fan.
  3. bigjerm
    Nov 18, 2014
    thanks. is a 12v regulator a single part i can buy or would it be a circuit i need to build?
  4. wayneh
    Sep 9, 2010
    12,374
    3,226
    Look up 7812 voltage regulator. It needs a couple of components - capacitors to prevent oscillation.
  5. bigjerm
    Nov 18, 2014
    thanks. could you explain to me how it would be hooked up? or link me to some place where i could learn?
  6. goahead113
    Dec 6, 2010
    <SNIP>
    The fan wont run with this wired up at 4v as the vdrop across regulator it will only be out putting under 2v or a transistor can be added to turn it off completely.
    Moderators note: link contained information that violates the ToS
  7. Dodgydave
    Jun 22, 2012
    5,142
    768
  8. blocco a spirale
    Jun 18, 2008
    1,459
    369
    For a small fan; all you need is a 12V zener diode connected in series. The dissipation of the zener will equal the power of the fan so make sure you use one with a suitable power rating.
    Also, Check the fan specification to see what its maximum voltage is. If the fan is ok at a voltage >12V you can use a lower voltage zener which would reduce the dissipation in the diode and improve the efficiency.
  9. MikeML
    Oct 2, 2009
    5,451
    1,066
    Is the fan going to be powered from the 4-24V signal, or is that just used to switch on/off a separate 12Vdc power supply that will power the fan?
