230v relay switching problem with rf
Discussion in 'General Electronics Chat' started by vijaybe, Dec 18, 2014.
  1. vijaybe
    May 27, 2014
    I'm facing relay switching problem by using RF.I'm using the relay in RF Receiver side.I tried with RC snubber circuit in relay coil and relay contacts.But i can't find any solution for that.Relay switching time differs for snubber circuit(tried with different R and C combinations).
    I couldn't switch the relay for right timing through RF receiver. Pls give solutions for this......
    - - - Updated - - -
    hi,
    Here i'm using industrial gong bell as a load.
    RF input is given to transistor base.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    What feeds R1? (voltage?, current available?)
  3. Alec_t
    Sep 17, 2013
    5,971
    1,135
    There's your problem. You need DC on the base.
    We don't know what voltage you intend to apply to R1, but R1=10k is probably much too high. Assuming your relay coil needs 100mA to operate, you need ~10mA base current.
