Need some help choosing diode modules to build a rectifier for a 225 amp AC welder. I've been researching this for a while and seen people use everything from antique Russian stud diodes of unknown capacity to nice brand new components that cost twice as much as buying a DC welder.
Output specs on the welder are:
225A/25V/20% duty cycle, 79V max OCV
The cleanest setup I've seen was using two IXYS MDD95-22N1B dual rectifier modules that are rated at 2200V, 180A each.
I understand wanting to give yourself some head room so using two modules totaling 360A makes sense, but is the 2200V necessary or can I go with something rated a little lower?
What would be the best balance between reasonable packaging (would like to get it inside the case of the welder), price, specs, and availability?
Oh, and one more question while I'm at it...would powdered iron packed inside an iron pipe make for a reasonable inductor/choke core? I think I'm going to need all the help I can get in that area.
Thanks for any help.
