220VAC to 55VAC
Discussion in 'General Electronics Chat' started by almasy, May 21, 2010.
  1. almasy
    Oct 1, 2009
    6
    hi everyone.
    I have a circuit automatic voltage regulator(AVR) for diesel generator.
    From the image
    Voltage input = 55VAC
    How to use 220VAC without transformer.
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    You MUST use a transformer, otherwise the circuit will be UNSAFE.
    Bertus
  3. retched
    Dec 5, 2009
    5,201
    313
    Why would you want to do ALL that when a simple transformer will suffice?
    Maybe telling us what you are trying to do would help. (besides getting 55vac from 220vac) A run of the mill 4 to 1 transformer will do the trick.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If this is your intent, you are mistaken. The diode bridge is an input structure, not some means of making that AC voltage noted as "implementation".
    The AC input clearly requires 55 VAC. The source will be either a special winding or a transformer.
    The circuit is an incomplete AVR, as that PWM input is not described in any way, nor the characteristics of the field winding.
  5. guru200773
    Member
    Apr 26, 2010
    94
    AVR means? :confused: :confused:
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Automatic Voltage Regulator
