I want to alter a water heater to heat to a higher outlet temp. I want the bottom to remain the same but the top to be able to heat up to at least 185 F when needed. This is obviously not to be used as a regular water heater for just shower purposes. What could i use to remove the upper thermostat and control the upper element only to this degree?. it would be nice if i had a variable control to get the water even hotter/cooler if desired and digital controls would be nice. 220v is what the water heater runs out of now. is there a way to convert to a 110 plug that can upped to 220. I don't think that is possible but if someone knows a way to answer that dumb question, please do. Pretty sure i know the answer... i found a 185 degree temp sensor for a car, but i don't know if that could work with some kind of relay from dc to ac or (and i am hoping there is)if there is an obviously better choice of equipment. this project is going to be great if i can get it to work. Kinda experimental design for something so forgive me if i am vague. I just hope there is a way to do it! Thanks for whatever and please forgive my ignorance to what and where to find components. MB
I am thinking of using an oven control circuit, using the thermostat and capillary tube. Does this sound like a good solution. Was thinking i could use the whole ciruit including the digital controls and just using the connection from the oven element and hooking it up to the water heater element and then creating a water tight way to insert the sensing bulb into the water heaters output line. Let me know what you think.
