220 Volt Dimmer/Speed Controller
Discussion in 'General Electronics Chat' started by Metalmann, Apr 28, 2013.
  1. Metalmann
    Thread Starter Active Member
    Dec 8, 2012
    700
    223
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Ouch! What are you trying to do? That dimmer can be used to control incandescent lamp and other resistive loads. A LED is a quite different kettle of fish.
    Metalmann likes this.
  3. praondevou
    Jul 9, 2011
    2,936
    489
    Since this seems to be phase controlled dimming I wouldn't use it for LEDs. I assume you mean the power LEDs for 110VAC with a built in AC/DC converter.
    If it was only LEDs and resistors it may work. I only see a pot, a diac, a capacitor like component and a TO-92 (SCR/triac?)
    After a quick look at digikey the lowest voltage forward drop for a TO-92 SCR is 1.2V. The TO-92 has a typical max power dissipation of 600mW if I'm not mistaken. For 100W that would be about 1W for the SCR. In other words, I wouldn't be so sure if it's good for continuously 100W... Depends on the SCR of course.
  4. Metalmann
    Dec 8, 2012
    700
    223
    I guess my main question would be....can it be used with 115V instead of 220V for LED dimming, motor control, etc.....as long as it would be under 100 Watts.?
    I don't understand why it couldn't be used for 115V.:confused:
    I have a lot to learn......;)
