There are many commercial 220 to 110 volt transformers to purchase. I'm assuming this is a typical 2:1 step down transformer. If you hooked 110 Volt's to the primary side would it be possible to obtain 55 volts on the secondary side?
I need a 1500+ Wattage 2:1 transformer with a 110 input and anywhere from 30-60V output and the 220 - 110 transformers are much cheaper, so was wondering if I could use them instead?
Thanks,
Surfline
Thanks,
Surfline
