220 dc to 220 ac
Discussion in 'General Electronics Chat' started by farm boy, Mar 24, 2009.
  1. farm boy
    Mar 24, 2009
    8
    I have a HUGE battery stack, old Telkom stuf, I charge them with a Lister diesel genni. I currently use a 1700w inverter to convert 48v dc to 220 ac,
    If I stack the Batteries to pour out 220 dc, is there a way to get higher wattages this way by switching the dc to give ac? am I making sense?:confused:
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Watts are the product of volts times amps. AC volts RMS times AC current RMS are the exact equivalent to the same measurement made with DC volts and current.
    Any conversion (inverter or motor - generator) will lose energy due to inefficiency.
    What is the application?
  3. farm boy
    Mar 24, 2009
    8
    Sorry, I don't think I'm getting across. My inverter is to light in the pants. I have the batteries to give me 220v dc at a rate of litteraly hundreds of amps, just need the 220 dc to be ac, ? switching ?50Hz transistor,triac?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  5. farm boy
    Mar 24, 2009
    8
    trying to bypass the inverter in favour of dc switching, guess I want to know if I have a 555 timer doing the timing for a Switching device(circuit), what would I use to switch the 220vdc, that could handle the kind Kw I'll be dealing with, would that be possable, even more expensive than stacking inverters?
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Not knowing anything about the application or the power involved, I can't guess.
  7. farm boy
    Mar 24, 2009
    8
    Sorry one of my posts got lost in a sever reset. I opperater lathes,milling machines, grinders, for short bursts, and sporadicaly,Normally I start the genni. The genni runs 3hours a day anyway to boost batteries,pump water and to run the fridges.
  8. farm boy
    Mar 24, 2009
    8
    [​IMG] [​IMG]
  9. farm boy
    Mar 24, 2009
    8
    Sorry, and thanx for trying,Jaques
  10. farm boy
    Mar 24, 2009
    8
    Can think of another way to possably attempt it. stackthe batteries in 48v stacks and use Irfba 1405p-nd (55v 170A n-channel mosfets) with a sincronised switching circuit(555)?
