22 bit adc and arduıno uno
Discussion in 'Embedded Systems and Microcontrollers' started by ozan, Apr 4, 2015.
  1. ozan
    Mar 8, 2015
    5
    Hi Everybody
    I have a problem related to adc(mcp3553) and arduıno uno (it can be a mıcrocontroller.First of all let me mentıon my project .Data that I got from straın gages is amplified by AMP04(gain:200) and I gotta convert the data that is amplified. and then if it's done .I'm gonna make the communicate xbees(s2) each other.Please help me
    Thanks in Advance
    ozan SEREN
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I cannot construct a mental picture from your words. Please post a readable schematic diagram.
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    To get 22bits of anything you have to go to extraordinary lengths to eliminate ground loops, digital noise, thermal drift, get drift-free reference voltages, etc, etc. I can predict right now that you will be lucky to get 12bits...
    RichardO and blueroomelectronics like this.
  4. tshuck
    Oct 18, 2012
    3,531
    675
    I'm missing what the problem is.
    You may (will) have an issue getting anywhere near 22-bits of usable data, however...
  5. ozan
    Mar 8, 2015
    5
    pictures
  6. ozan
    Mar 8, 2015
    5
    how can I write program for mıcrocontroller actually ı want to disassembly just atmega328 and I want to do ıt vıa that
  7. MrChips
    Oct 2, 2009
    12,624
    3,451
    You have serious flaws in your design. MCP3553 ADC accepts differential inputs. You want to take full advantage of this.
    Remove all your opamps and connect the ADC differential inputs directly to the bridge.
    As others have said, you will not achieve anything close to 22 bits.
  8. tshuck
    Oct 18, 2012
    3,531
    675
  9. OBW0549
    Mar 2, 2015
    1,389
    932
    The schematic shown appears to come from this document,
    http://complex.umd.edu/papers/dissertations/new_torque_schematic_dissertation_Daniel_Zimmerman.pdf
    which is a correction to the diagram shown on page 310 of this doctoral dissertation,
    http://complex.umd.edu/papers/dissertations/dissertation_Daniel_Zimmerman.pdf
    by one Daniel S. Zimmerman.
    Zimmerman lists a URL for his Arduino source code, but it appears to be a dead link.
    To ozan: I think your best course of action would be to try to contact Dr. Zimmerman and ask him to email you the source code or give you a valid web link to it.
    For any of us here to help you, we would have to design the entire application for you and I doubt anyone would be willing to do that.
  10. Papabravo
    Feb 24, 2006
    10,340
    1,850
  11. djsfantasi
    Apr 11, 2010
    2,900
    876
  12. OBW0549
    Mar 2, 2015
    1,389
    932
    Pure luck. I looked at the schematic this fellow posted and got curious about the "Futek TF600" load cell he wanted to use; and when I googled that, one of the links that popped up was to Zimmerman's original schematic. And from there, I backed up one level and saw his full dissertation.
  13. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Wow. I tried a couple of possible searches, but found no happiness.
    I suppose he must be trying to duplicate the original results.
