20w inverter ???
Discussion in 'The Projects Forum' started by onlyvinod56, Jun 22, 2012.
  1. onlyvinod56
    Thread Starter Active Member
    Oct 14, 2008
    362
    Here iam attaching a schematic.
    Its a 20W inverter(emergency lamp) circuit.
    Its not a copy from any source.
    I know that a 555 acts as free running oscillator in astable mode.
    Keeping the astable multi concept in mind, i have designed the shown circuit.
    When i connected 12v DC supply, the output is around 1000v without load.
    But when the load (15W bulb) is connected it is not glowing.
    12V dc supply is from a regulated power supply having a maximum current range of 0-2A max.
    What is the problem here?
      File size:
      18.6 KB
      50
  2. #12
    Nov 30, 2010
    16,676
    7,320
    That transformer should do less than 100 volts. Are you sure you didn't read the meter wrong? [12 x 450/58 = 93V]
    It won't hold up under load because you have a 1k resistor limiting the drive current to about 10 ma and the 3055 transistor has low gain. It can allow less than 1 amp under those conditions, and that is less than 12 watts of input to the transformer.
    In another thought, running a transformer in one polarity only causes trouble with the magnetism saturating the core. I'm not good at this part so I will expect someone to clarify for me.
    That's what I can see for improvements.
    Edit: A Thanks to cork_ie for spotting something I didn't notice.
  3. cork_ie
    Member
    Oct 8, 2011
    348
    58
    Unless I am badly mistaken you are running this at about 7KHZ and 50% duty cycle if potentiometer is in mid position. 2N3055 should be OK at this kind of frequency.
    What kind of transformer are you using?
    Could you try this with a 2.2uF capacitor and see what happens?
    #12 likes this.
  4. Sensacell
    Jun 19, 2012
    1,183
    276
    Your design uses the transformer in flyback mode, without a load, the output voltage will be huge as the energy stored in the transformer core has nowhere to go- except maybe toasting your driver transistor. Most inverters of this type use a push-pull symmetrical design that allows unused energy stored in the core to be returned to the 12V power supply- very much like a regular transformer running on ac would. google "12 volt inverter circuits" - you will see many examples of this concept.
    #12 likes this.
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    As noted the frequency will probably to high for the transformer.
    Also the base resistor for the 2N3055 is to high.
    Now the transistor will not be switched full.
    A base resistor of 68 Ohms will work better.
    (creating a base current of about 0.2 A).
    Bertus
  6. cork_ie
    Member
    Oct 8, 2011
    348
    58
