20A Dummy Load
newhobby
Joined Mar 26, 2014
24
I need to test a constant current circuit up to 20A.
My real load is a light diode with about 2.5V forward voltage and I don't want to use it to test the circuit as it is pretty expensive.
What would you recommend for a dummy load?
#12
Joined Nov 30, 2010
18,224
C'mon guys, 80 watts worth of resistors on a 50 watt supply isn't going to need liquid cooling. :rolleyes:
and 12 volt light bulbs don't work very well on 2.5 volts. :p
wayneh
Joined Sep 9, 2010
17,498
...and 12 volt light bulbs don't work very well on 2.5 volts. :p
Haha, yeah, missed that. I even double checked for the OP's voltage but that didn't register. I gave blood last night. Let's blame that.
The resistors will work just fine. Just let them breathe.
