208VAC current draw
Discussion in 'General Electronics Chat' started by Brian Pahlas, Oct 20, 2014.
  1. Brian Pahlas
    Oct 20, 2014
    If we have a 220VAC L6-20 connection and we have a load of 2400W, then 2400W / 208V = 11.5 A.
    Is that 5.75 amps per hot leg ? Or can it not be expressed that way.
    Thanks for your help,
  2. pwdixon
    Member
    Oct 11, 2012
    488
    56
    So if i read this right an L6-20 connection is just a mains connector with a live, a neutral and an earth.
    How did 220VAC suddenly become 208V when you wanted to calculate the current?
    If by hot leg you mean live/neutral then the full current passes through both pins I'm afraid.
  3. Brian Pahlas
    Oct 20, 2014
    We generally say 220V, but we really only get about 208V. I used 208V for a more accurate calculation, but it was not really necessary for this example.
    A NEMA L6-20 has two hot legs and a ground ( X, Y, G ) . This is being used to power a large projector.
    Thank you for your time and help.
  4. KMoffett
    Dec 19, 2007
    2,584
    234
    220/230/240vac is the standard voltage between the two phases of the residential power supplied in the USA. 110/115/120VAC is taken from neutral to either phase. 208vac is the voltage taken between any two phases of a three phase Y-system, with 120vac from any phase to neutral.
    Ken
