20 inputs and 20 outputs GSM Controller
Discussion in 'The Projects Forum' started by bowlingo, Nov 12, 2011.
  1. bowlingo
    Jun 29, 2011
    162
    Hi all,
    I am currently using 3 of these of which involves using 3 x sims etc..I need around 20 outputs, 20 inputs and 2 x analogue inputs that will be 4 - 20mA
    http://gsmalarmsystem.en.alibaba.co...ontroller_RTU5011_8I_O_Ports_4AD_Inputs_.html
    And I have achieved the following prototype of which I video'd last sunday
    http://www.youtube.com/watch?v=OXPj1c08LBw
    I now want the electronics to be a lot more streamline without banks of nasty timed relays, wires all over the place and reels of solder being used :confused:
    I believe these to be the answer
    http://www.mikroe.com/eng/products/view/419/picplc16-v6-plc-system/
    I would need two of these joined together and the GSM unit.
    The trouble is I cant afford the money it will cost to get someone to code them for me so I am thinking of buying one board and the gsm module and trying to learn how to do it myself...would you consider this a wise move? Seeing as I have never programmed anything before?
    Alex
  2. panic mode
    Oct 10, 2011
    1,330
    305
    that certainly looks like right product for the job.
