2 x square wave oscillators - unwanted modulation
Discussion in 'Digital Circuit Design' started by Tony Elliott, Jul 10, 2016.
  1. Tony Elliott
    May 8, 2015
    140
    Hi All-out circuits,
    I am using two square wave oscillators, when i put the outputs together they modulate. you can see the schematic attached. I don't want this modulation. Is there a way of fixing this, maybe an idea to use a diode on each output?
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    IC1 is the 555 oscillator.
    IC2A is a divide by 2 circuit.
    What do you mean with modulate ?
    Bertus
  3. Tony Elliott
    May 8, 2015
    140
    Both square waves connect as one modulating pattern. it sounds great but I would like to have two separate square waves on the oscilloscope and speakers.
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  5. Tony Elliott
    May 8, 2015
    140
    Here is some footage of me playing with the modulation.
    The schematic itself is not mine so I just followed the design.
  6. benta
    Member
    Dec 7, 2015
    101
    24
    Why are you connecting the outputs?
  7. BobTPH
    Jun 5, 2013
    806
    121
    It might help if you clued us in as to how the two signals are combined.
    Bob
  8. GopherT
    Nov 23, 2012
    6,304
    4,027
    Please show the rest of the schematic datasheet (source of your attachment in post 1).
  9. Tony Elliott
    May 8, 2015
    140
    I have two circuits and connect x2-2 on the first to the second circuit and connect the x2-1 on the first circuit to the second circuit
  10. Tony Elliott
    May 8, 2015
    140
    I was emailed this data sheet so sorry i don't have a source
  11. GopherT
    Nov 23, 2012
    6,304
    4,027
    Use the Upload file button as you make a post and attach the datasheet. PDF files and most image files are acceptable.
  12. Tony Elliott
    May 8, 2015
    140
  13. GopherT
    Nov 23, 2012
    6,304
    4,027
  14. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Your 555 circuit is producing needle pulses, as there is no resistor in the discharge line.
    See the following drawing for more info:
    Bertus
    Tony Elliott likes this.
  15. Alec_t
    Sep 17, 2013
    5,971
    1,135
    :confused: There are 4 connection points. You mention only 2.
  16. Tony Elliott
    May 8, 2015
    140
    the first two connections are the battery inputs,
  17. Tony Elliott
    May 8, 2015
    140
    this looks interesting, I will experiment with this, I could even make pulse with stretcher.
  18. BobTPH
    Jun 5, 2013
    806
    121
    So one square wave oscillator is supplying power to a second square wave oscillator. What do you expect the result to be?
    Bob
  19. Tony Elliott
    May 8, 2015
    140
    No there are two of these circuits, and when both outputs are connected in a passive mixer I get two modulating square waves.
  20. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
