2 transmitters on 1 antenna - will it work
Discussion in 'Wireless & RF Design' started by Jsabah, Nov 13, 2015.
  1. Jsabah
    Oct 31, 2015
    I have a 315 MHz transmitter in a metal box with an RG-174 coax to a remote 1/4 wave antenna. I need to add a second transmitter because I need to transmit 2 signals simultaneously but I only have room for a single remote antenna. Can 2 transmitters transmit simultaneously using the same antenna? Appreciate any help.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    No, not simultaneously. You would have put the transmitters on different frequencies, and use a device called a "circulator" or "duplexor" to combine the RF signals onto one coax to one antenna. If the transmitters send their messages sequentially (only one keyed at a time), it is much easier.
