2 kW motor speed controller
Discussion in 'The Projects Forum' started by darsie, Mar 13, 2014.
  1. darsie
    Feb 19, 2010
    15
    Hi!
    My flat mate bought a defective treadmill cheaply and has now bought several motor controllers from other treadmills, struggling to figure out how to connect/drive them. I suggested building a controller but he's reluctant as his electronics fu is rather small (yet).
    What do you think about this PWM scheme?
    The capacitor shall avoid 50 Hz hum in the motor. The inductor shall avoid current transients in the transistor. Also there will not be a current transient through the rectifier to the capacitor when the thing is plugged in.
    Thx, Bernhard
  2. darsie
    Feb 19, 2010
    15
    Ahh, the diode should span the motor and the inductor.
  3. R!f@@
    Apr 2, 2009
    8,789
    771
    A transistor as a power switch. That won't do.
    Get a MOSFET or an IGBT
    Next thread motor needs a steady DC. That is mains rectified smooth DC. The power switch will control the motor.
    And this thread will get locked soon if you plan to do what you drew.
  4. R!f@@
    Apr 2, 2009
    8,789
    771
    Yikes ! 2KW on a thread mill ?
    Are u sure ?
  5. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,513
    Instead of buying controllers out of T.M.'s he should have looked for a KB/Baldor DC controller, many come up on ebay.
    They have SCR bridge versions or (better) PWM tyes.
    Max.
  6. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,513
    Don't be fooled, if you compare the frame size of 2-2.5Kw motors out of T.M.'s with industrial DC motor of the same HP you can see the difference!
    Max.
  7. darsie
    Feb 19, 2010
    15
    I just drew the (incomplete) transistor symbol as I hadn't decided what switch to use. Hmm, not sure if a suitable MOSFET can be driven with an avr microcontroller output. Perhaps if the switching frequency isn't too high. Maybe 20+ kHz to get out of audible.
    Anything wrong with the smoothing capacitor I drew?
    Here's an updated circuit:
    Do you think a 400V transistor will do?
    So, the general scheme is ok?
    He says, it's 2 1/2 HP, which is 1839 W.
  8. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,513
    PicMicro claim that is only necessary to go as high as 4Khz PWM with motor circuits above this there is little audible difference, so they claim.
    You can either get Mosfet driver IC's or use a logic level Mosfet Gate.
    Max.
  9. strantor
    Oct 3, 2010
    4,302
    1,989
    IGBT or MOSFET would definitely be better, but a transistor could be and has been used. The older VFDs had darlingtons in them.
    You probably know more specifically about the treadmill motor than I do, but would have thought that it's not too picky about input power. DC drives (other than PWM) for industrial DC motors usually have SCR output with no filter caps. They just phase angle fire rectified AC into the motor. The motor is pretty stupid and doesn't know the difference. Perhaps treadmill motors are more picky?
  10. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,513
    T.M.'s are pretty basic, I have used them with both SCR full-bridge controllers or PWM, the SCR's are a bit noisier, especially at low rpm, the PWM give a little more top end RPM due to the higher DC level.
    This is why T.M. controllers are typically PWM.
    Max.
  11. R!f@@
    Apr 2, 2009
    8,789
    771
    Mostly TM motors run at full speed around 180V to 200V DC.
    For smooth speed at low RPM, there should be feedback.
  12. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,513
    Most do, in the form of a slotted opto sensor.
    Max.
