Hi Everyone,
I have two devices which works synchronizing eachother. The synchronization signal is 2 kHz. You can see its signal characteristic at attached picture (The red one is synchronization signal). While transfering this signal from one device to second one, it is distorting because of noise. So, devices don't work properly. Beacuse, they must synchronize to each other. Distance between two device is maksimum 5 meters. I need a component or a circuit which is able to fix the distorted signal. Or this component or circuit able to tolerate distortion. Can anyone provide a solution or suggest a component related with my problem? What can be done?
P.S : Amplitude of synchronization signal is between zero and negative 0.8 Volt as you can see the picture. (0<signal<-0.8 Volt)
