2 days of work, gone!!
Discussion in 'Off-Topic' started by CVMichael, Sep 19, 2012.
  1. CVMichael
    Thread Starter Senior Member
    Aug 3, 2007
    416
    17
    I spent 2 full days (morning till night), last weekend, to make a PCB board for the motors drivers for my robot. 4 DC motors and 1 stepper motor connected to a PIC32 microcontroller.
    I was working on my robot yesterday, and I was connecting the battery jacks to the PCB board. The batteries are in parallel, in total of 12V 16 Amps, I connected the negative, and plugged the jack in the PCB, then I took the positive wire (to connect it to the jack), and it slipped through my fingers, and it touched the PCB board on a trace where the negative was.
    It melted the traces of the PCB, and then the PIC32 chip popped, and burned, and who knows what else is burned (probably everything)...
    I know all the mistakes I made, you don't have to tell me...
    I am so sad :( I just had to let it out...
  2. Sparky49
    Jul 16, 2011
    835
    417
    Welcome to everyday electronics! :D
    Sorry for your loss, RIP (Rest In Pieces)
  3. MrChips
    Oct 2, 2009
    12,652
    3,461
    Live and learn. It has to happen to each one of us once in our lifetimes.
  4. BMorse
    Sep 26, 2009
    2,675
    234
    Once?!? I must be taking more of my fair shares then :)
    Did that once with my Pic32 starter kit, was testing interrupts when I touched my "interrupt" trigger wire (which was connected directly to ground) and accidentally touched the +V rail and "pooof!", board was dead...
  5. CVMichael
    Aug 3, 2007
    416
    17
    Thanks guys... I feel better now...
    I hope I can re-make the PCB board quicker this time.
  6. m1ch43l
    Member
    Aug 16, 2012
    62
    This reminds me of all the dead timers, FETs, caps and my beloved arduino!
    @sparky49 conquer: RIP my beloveds...
  7. atferrari
    Jan 6, 2004
    2,673
    785
    But not quicker to burn it again...! :eek:
    ¡Buena suerte!
  8. m1ch43l
    Member
    Aug 16, 2012
    62
    Try building it in chunks then piece them together with organized interfaces(plugs) to prevent a repeat.
    This has helped me greatly.:D
  9. CVMichael
    Aug 3, 2007
    416
    17
    Trust me, after what happened, when I get to the point to connect the battery again, I will be extra carefull!
  10. BMorse
    Sep 26, 2009
    2,675
    234
    if it makes you feel any better, you can watch me fry my Pic32 starter kit here>> http://youtu.be/32j9wORr2_k it is around 0:41 secs into the video.... :) But I did manage to salvage the board by replacing the protection diode they had on the board, maybe you should add something like that to your next PCB...
  11. CVMichael
    Aug 3, 2007
    416
    17
    I'm at work now, so I can't (should not) watch videos...
    What "protection diode" are you talking about? Is it a regular diode? or a special diode for this purpose?
  12. ErnieM
    Apr 24, 2011
    7,443
    1,628
    One day at work (happened to be a Saturday doing unpaid overtime to meet a critical shipment date) I slipped a scope ground probe and instantly took out about $30K in test equipment: power shorted thru the IEEE-488 bus and took out the computer, a DVM, spectrum analyzer, electronic load, everything but the power supply itself.
    When my boss asked me about this Monday morning I told him the equipment was now in the calibration department for repair, I had borrowed other equipment from engineering, revamped the test program for semi-manual operation, and the parts would be on the shipping dock by lunch (on schedule).
    All he said in reply was "OK" and left me to my testing.
    Doo-doo happens. It's how you respond that counts.
  13. atferrari
    Jan 6, 2004
    2,673
    785
    ...and so awful
  14. loosewire
    Apr 25, 2008
    1,584
    435
    Two days tells the story ,too much stuff in two days.You need to take it slow and
    steady. Look at some of the boards posted in albums,look and see how many was
    done in two days.
  15. CVMichael
    Aug 3, 2007
    416
    17
    By the way, I attached a picture I took before I burned it :)
      File size:
      154.5 KB
      32
  16. loosewire
    Apr 25, 2008
    1,584
    435
    Neat layout ,too much solder over flow....may have been down fall.
  17. CVMichael
    Aug 3, 2007
    416
    17
    The problem was that I short circuited the positive on the ground through the PCB board.
    The traces on the back side melted in like 6 places, and then current flowed through the components. There was a huge spark when the wire touched the PCB, and the PIC32 had a small flame in the center.
    The batteries are 16 Amps, so it's no surprise that everything melted :D
  18. loosewire
    Apr 25, 2008
    1,584
    435
    You are taking well,that a good sign...you will do better next time..are you
    comitted to electronic stuff.
  19. CVMichael
    Aug 3, 2007
    416
    17
    By the way... is there some kind of insulator like a paint, that I can just brush on top of the PCB and components?
    Theoretically it should be something like this, right?
  20. loosewire
    Apr 25, 2008
    1,584
    435
    Ask the guys.....maybe varnish. Good work don't need it.
    Maybe better board material.
