The code below should display a 16 bit number on the USART as 2 seperate byte,MSB and LSB one after the other on the same recieved line, our output should look like
10 = 256
11 = 257
12 = 258
13 = 259
instead it outputs
Received: 0 0
Received: 1 2
Received: 2 3
We know that the loop is incorrect, we think it is re-reading the same address line, can anybody help??
int i;
long j, byte_Byte1, byte_Byte2;
unsigned short temp_res, temp_res2;
void EEPROMWriteInt(int p_address, long p_value)
byte_Byte1 = ((p_value >> 0) & 0xFF);
byte_Byte2 = ((p_value >> 8) & 0xFF);
EEprom_Write(p_address , byte_Byte1);
EEprom_Write(p_address +1 , byte_Byte2);
void main() {
ANSEL = 0; // Configure AN pins as digital I/O
ANSELH = 0;
PORTB = 0; // Initial PORTB value
TRISB = 0; // Set PORTB as output
PORTD = 0;
TRISD = 0;
j = 257;
for (i = 0; i < 3; i++)
// Write some data to EEPROM
/* EEprom_Write(i, j++); */ // at addresses 0..3
EEPROMWriteINT(i,j++) ;
Delay_ms(50);
for (i = 0; i < 3; i++) {
USART_Init(19200); // Initalize USART (19200 baud rate, 1 stop bit, no parity...)
ns as digital I/O
temp_res = PORTB; // Read 10-bit ADC from AN2 and discard 2 LS bits
temp_res2 = PORTD ;
Delay_ms(100);
PORTB = EEPROM_Read(i); // Read data and display it on PORTB
PORTD = EEPROM_Read(i+1) ;
USART_Write(temp_res); // Send ADC reading as byte
USART_Write(temp_res2);
Delay_ms(500);
10 = 256
11 = 257
12 = 258
13 = 259
instead it outputs
Received: 0 0
Received: 1 2
Received: 2 3
int i;
void main() {
ANSELH = 0;
PORTD = 0;
TRISD = 0;
j = 257;
Delay_ms(50);
ns as digital I/O
temp_res2 = PORTD ;
Delay_ms(100);
Delay_ms(500);
