2 ac-ac SSRs in Parallel, Only one on at a time
Discussion in 'General Electronics Chat' started by Uber_Goober, Mar 15, 2016.
  1. Uber_Goober
    Jan 19, 2013
    45
    I'm using a temperature controller to maintain the temperature in my wine cellar. It controls an air conditioner and a space heater and works fine.
    I'd also like to turn on a fan when either the AC or Heater turn on.
    I understand that SSRs aren't supposed to be used in parallel to increase current output. But can they be used in parallel when only one of them will ever be on at a time? I'm thinking to use 2 ac-ac SSRs with inputs connected directly to the AC and Heater power, and then or-wire the SSR outputs to power the fans.
    I'm thinking this should work, but I thought I'd check in here. Is there a better/simpler way?
    Thanks!
  2. crutschow
    Mar 14, 2008
    13,475
    3,362
    Normally the control input for the SSR is DC.
    Are the control signals to the AC and Heater also DC?
    If so then just use one SSR and diode-OR the two inputs (one diode in series with each input) to the fan SSR input.
    That way either input will turn on the fan but the two inputs won't interfere with each other.
  3. Uber_Goober
    Jan 19, 2013
    45
    No- my controller uses relays putting out 115vac directly for the AC & Heater, so I have to go off that- hence the SSRs with AC inputs.
  4. #12
    Nov 30, 2010
    16,665
    7,310
    Must use high tech?
    AnalogKid likes this.
  5. Uber_Goober
    Jan 19, 2013
    45
    I like it, thanks!
  6. tcmtech
    Nov 4, 2013
    2,107
    1,747
    But are the connections to be crimped or soldered or both? :confused:
  7. Uber_Goober
    Jan 19, 2013
    45
    Looks like I'll do crimped conections.
  8. tcmtech
    Nov 4, 2013
    2,107
    1,747
