2-5V to 4-20mA converter
Discussion in 'The Projects Forum' started by dhooker, Jul 10, 2009.
  1. dhooker
    Jun 9, 2009
    11
    I know there are loads of designs out there but a quick, simple (few components) solution is what I am after.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    That'll take a couple of opamps, a half-dozen resistors or so (mostly fixed), a transistor and a few caps.
    Is that too compex?
  3. millwood
    Guest
    one opamp, one transistor and a few resistors.
    you can also do it with a lm317-type device.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,729
  6. ELECTRONERD
    May 26, 2009
    1,146
    16
    Yikes! :eek:
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Wow, Gunny - no wonder I'm so impressed. Op amps it is.
  8. pilko
    Dec 8, 2008
    213
    20
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    The attached should do it.
    R1 through R4 and Vee (-5v) are critical values.
    R5 is just there to limit maximum output current from the opamp in case Q1 fails.
    Q1 is used as a voltage follower. Although the LM358/LM2904 opamp used can source a minimum of 20mA, that's pushing the specifications. Just about any general-purpose NPN transistor could be used instead of a 2N2222.
    Maximum load impedance is about 728 Ohms with a 20v supply.
  10. millwood
    Guest
    if you use a chip like tda2030, or lm1875, and your load can be floated, you don't need that transistor. just get rid of R5 and put the load between the opamp's output, and tie the other end to the feedback, then you have gotten yourself some CCS!
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    LM1875's run around $3/ea.
    TDA2030's run around $2/ea.
    LM2904's run around $0.40 each, and the transistors are around $0.10 if you're buying singles.
  12. dhooker
    Jun 9, 2009
    11
    Many thanks for all your ideas
  13. BillB3857
    Feb 28, 2009
    2,402
    348
    My guess is that $20 is for the 4-20 conversion and $100 is for the isolation.:)
