2.5V Refernce LM4128 problem
Discussion in 'General Electronics Chat' started by mcgyvr, Jul 9, 2012.
  1. mcgyvr
    Thread Starter AAC Fanatic!
    Oct 15, 2009
    4,794
    978
    Having a problem here..
    I'm using the attached circuit to measure -75 to 75V and output it to 0-5V for sampling by a micro (2.5V -/+2.5V).
    Except instead of the 2.5V voltage as shown in the image I'm using a LM4128 2.5V series voltage reference. (personally never used a voltage reference chip before)
    Reading negative voltages works just fine and the output of the LM4128 stays stable at 2.5V. (Vout goes from roughly 0V to 2.5V as Vmeasured goes from -75 to 0V as I want)
    The problem is measuring positive voltages.. At about 10V into Vmeasure I'm getting 4.5V or so at the output of the LM4128 causing the circuit to not work properly. (basically as Vmeasure is going up positive Vref is also going up)
    ??help
    Here are the voltages I'm measuring at Vout (don't have the micro attached yet..All measurements made with a fluke multimeter)
    Vmeasured----Vout
    Negative input voltages
    0V=2.5V
    -10V=2.17V
    -20V=1.84V
    -30V=1.51V
    -40V=1.19V
    -50V=0.86V
    -60V=0.53V
    (basically .33V per 10V) OK..Seems to work fine..
    NOW..
    Positive input voltages
    0V=2.5V
    5V=2.75V
    6V=3.18V
    7V=3.64V
    8V=4.02V
    9V=4.57V
    10V=4.57V (stops here and won't go any higher)
    If I replace the LM4128 with a 2.5V power supply all works just fine. Maybe the LM4128 is damaged? (edit..Just tried another LM4128 and no change)
  2. #12
    Nov 30, 2010
    16,705
    7,358
    Does this do you any good?
  3. mcgyvr
    Oct 15, 2009
    4,794
    978
    No removing R4 doesn't help.
    Or ..Are you also saying I need to reduce the resistor values too?
  4. #12
    Nov 30, 2010
    16,705
    7,358
    What I'm saying is that I completely ignored your circuit and designed one that will convert +/-75V to 0-5V where +75 gets 0 volts out and -75 gets 5 volts out.
  5. mcgyvr
    Oct 15, 2009
    4,794
    978
    No you didn't. It needs r4 to function properly I believe.
    And that doesn't help me at all.
  6. #12
    Nov 30, 2010
    16,705
    7,358
    Somebody else will give it a try.
  7. mcgyvr
    Oct 15, 2009
    4,794
    978
    o...k... ummm.. thanks I guess?
    Still need help..
    I just don't know why a 2.5V voltage reference IC is different than just a 2.5V regulator.
    That seems to be the problem.. Why isn't the 2.5V reference behaving like a regular 2.5V regulator when positive voltages are trying to be measured.
  8. mcgyvr
    Oct 15, 2009
    4,794
    978
    anyone..anyone.. beuller..beuller??
    Is it that this LM4128 voltage reference cannot sink current as its required with positive input voltages??
    If so can someone recommend a 2.5V reference that can sink enough current for my application..
    (maybe like MAX6100-MAX6107 or MAX6225)
  9. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    I use LM7805 with 470 Ohms voltage divider for 2.5V reference.
    Don't know if it can sink current.
  10. MrChips
    Oct 2, 2009
    12,652
    3,461
    I wouldn't post my suggestion until I get a chance to test it on a breadboard.
  11. mcgyvr
    Oct 15, 2009
    4,794
    978
    Any suggestions are appreciated.. I think I'll order up some of the MAX chips or try to find another that can source/sink
  12. mcgyvr
    Oct 15, 2009
    4,794
    978
    How about just adding a 1k (1/16w?)resistor from the output of the 2.5V ref to ground to ensure a load is always there? Any possible problems with that?
    When I add that resistor I get the proper output for both positive and negative voltages.
  13. MrChips
    Oct 2, 2009
    12,652
    3,461
    Here is my circuit:
    U1 is a single supply rail-to-rail op-amp.
    You can trim R1 for gain adjust and R2 for offset adjust.
  14. Ron H
    Apr 14, 2005
    7,050
    657
    Like most positive series references and regulators, LM4128 cannot sink current. Your load needs to sink more current than the measured voltage will source. 1K is OK.
  15. mcgyvr
    Oct 15, 2009
    4,794
    978
    yep just finished prototyping the complete circuit (way more than just the little bit I posted here.) and it all works perfect with simply adding the 1K resistor to ground..
    Thanks again to all.
  16. mcgyvr
    Oct 15, 2009
    4,794
    978
    Thanks..looks very simple.. I'll give that a try. I really like the gain/offset adjustments.
