2/3 watt meter problem
Discussion in 'Homework Help' started by needs, May 8, 2010.
  1. needs
    Mar 30, 2010
    16
    I have problems on 3 phase systems,
    what is the purpose of connecting the load star point to the supply neutral current while setting currents taken from supply?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    You tie the load star point to neutral to ensure the line-to-neutral load voltages are equivalent to the supply line-to-neutral voltages. A floating star point on an unbalanced (in particular) 3-phase load would lead to imbalance of the load line-to-star point voltages and hence unexpected load phase current values. It's sound procedure.
  3. needs
    Mar 30, 2010
    16
    Ohh Thanks very much!! i have another question when comparing results with the 2 or 3 watt meter methods, why is it necessary to disconnect the neutral?
    thanks alot!!
