2*3.5amp 12v chargers in parallel on a 12v lead acid battery, would there be any problems/issues doing that?...
I ask because i have a 150watt Inverter and 3.5amp alone is not enough to keep the battery topped up when using the computer with it If i could use 2 in parallel i could run the computer / monitor off of the inverter 24/7 using the chargers to keep the battery topped up....
or is it better to buy 1 charger of 7 amps?.... (I have a 3.5amp charger already)
