2.1VDC forward voltage needed for LED. What do I need to do to the circuit shown?
Discussion in 'Power Electronics' started by nbtone, Oct 14, 2016.
  1. nbtone
    Oct 14, 2016
    10
  2. ronv
    Nov 12, 2008
    3,404
    1,478
  3. SLK001
    Nov 29, 2011
    852
    243
    What purpose do the transistors serve?
  4. crutschow
    Mar 14, 2008
    13,509
    3,385
    Provide a return path for the LED current depending on which way the switch is positioned.
  5. SLK001
    Nov 29, 2011
    852
    243
    All that's needed for that is a ground. The transistors serve no useful purpose.
  6. crutschow
    Mar 14, 2008
    13,509
    3,385
    And how would that work when you throw the switch? :confused:
    The two LEDs are in one package with only two leads.
    #12 likes this.
  7. SLK001
    Nov 29, 2011
    852
    243
    Oh, yeah... I was looking at only one path. It would be cheaper to use two separate LEDs, but that isn't the question and maybe isn't even possible for the application.
    #12 likes this.
  8. nbtone
    Oct 14, 2016
    10
  9. ronv
    Nov 12, 2008
    3,404
    1,478
    Hmm, Seems like it should have kind of worked. But lets see.
    The LED's want about 20 ma and drop about 2.1 volts. So basically 4.5 - 2.1 / .020. About 120 ohms for the top resistor.
    For the transistors to turn on "hard" they need about 1/10 the collector current for the base. Since the LED will hold the voltage to 2.1 volts and the transistor base emitter drop is about .6 volts you can calculate R base. 2.1 - .6 / .002. About 750 ohms.
  10. djsfantasi
    Apr 11, 2010
    2,911
    881
    Given @ronv 'S analysis, apply it to your circuit.
    In the switch position as shown, you will pass the current through a 1k8 Ω base resistor. This will apply only 0.8ma to the resistor, insufficient for it to switch the 20ma the LED needs. Since it does not light, I surmise the LED needs more than 8ma.
    Secondly, with an 82 Ω resistor on the LED, you'll have 30 ma of current. More than it's max rating. Have you damaged the LED?
  11. nbtone
    Oct 14, 2016
    10
    I tested the LED with 2 AA batteries, and it is okay. If I have 1.1VDC at the LED now, shouldn't I need a smaller resistor in place of the 82 ohm one? If I put a 120 ohm resistor, the voltage will be even lower, won't it?
  12. ronv
    Nov 12, 2008
    3,404
    1,478
    The LED voltage should be 2.2 volts if the voltage on top is 4.5 volts like in your diagram.
  13. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,705
    1,300
    Two resistors in series from Vcc to GND.
    One end of LED connected to the center node.
    Other end of the LED connected to the switch pole connection
    One switch throw connected to Vcc
    Other switch throw connected to GND
    ak
  14. nbtone
    Oct 14, 2016
    10
    Maybe I'll try putting around a 40 ohm resistor in place of the 82 ohm rsistor to see what happens?
  15. ronv
    Nov 12, 2008
    3,404
    1,478
    Before you do that, mark up the drawing with the values you have then measure the voltage at each point and write it on the drawing.
    Include the power supply voltage, each side of the led and the base of each transistor.
    Or look at AK's idea if you don't need to keep this one.
  16. nbtone
    Oct 14, 2016
    10
    Wait a minute. I've been playing with the ground reference in other parts of the circuit that uses this, and it's -4.5 VDC and not +4.5VDC. Does that make it easier?
  17. djsfantasi
    Apr 11, 2010
    2,911
    881
    So instead of 4.5v across the circuit, you have 9v. I think that makes a difference. Your LEDs are getting about 85ma. Not sure why they are still working at all.
  18. eetech00
    Jun 8, 2013
    685
    118
    You can also use a DPDT toggle switch instead of transistors.
  19. nbtone
    Oct 14, 2016
    10
    Here is a more complete schematic. The relay shows only one side, and there are two circuits that it switches. I was a little confused about where I was finding the voltage. I went and spent some more time studying, and these are correct voltages. The two 100 ohm resistors used to go straight to ground, but I've had to do some ground referencing. Now the LED won't work. Sorry about the earlier posts.
  20. ronv
    Nov 12, 2008
    3,404
    1,478
    Yeah, Your ground kind of disappeared.
    What is the LED supposed to show? The state of the red/green relay control?
