I have a bus with 2 large 12v batteries connected in series for a 24v system. Most of the load on the system is 24v and it charges via 24v alternator. There was some minor 12v load off both batteries for lights and other equipment. I added a large stereo system with several 1,000 watt amps. I'm drawing off one of the 12v batteries for power on the stereo.
Here are my questions;
1. will the uneven load affect the charging system?
2. does adding another smaller 12v battery in parallel to the heavy load side of the system affect charging/draw?
3 if I increase the capacity of the system, by adding 12v batteries in parallel, do I have to do it to both banks equally?
4 should I run 24v to some type of voltage reducer and place a bank of 12v batteries there for the high stereo load?
I have no way of equalizing the 12v loads between banks.
Thanks in advance.
Thanks in advance.
