2.048v Voltage Reference..
Discussion in 'The Projects Forum' started by Dr.killjoy, Apr 19, 2016.
  1. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    I have been working on building a single 2.048v reference in order to check calibration of my meter and other equipment..I choose to use the Maxim Max6126 which is 2.048v and 0.02% tolerance with 5ppm Temperature Coefficient..The reason I chose to use this voltage because it will show full value on all my DMM and should work for most people ...I will be working the design and schematic in diptrace.. The design is not done or even built yet but I am working on finally details in order for me to buy the parts and test and it should be really nice IMO..The unit will powered with a single 18650 cell with a cheap ebay usb charger and battery protection circuit .. I was going to use a normal switch to turn the unit on but will go with a monetary switch circuit I think..My only problem is whether to use all smd parts or use smd and through hole ?? I was thinking all smd since I don't a drill press and I can get away with drilling a couple holes by hand but not set on the idea yet..
    Any comments or suggestions ???
    Hopefully I will be posting a full schematic..
    Here is where I am pulling the circuit from and will be modding it to suit me
    Chip schematic
    Attached below
  2. dannyf
    Sep 13, 2015
    2,196
    417
    I hink whteve flats yur bat wil be ine wth us.
  3. GopherT
    Nov 23, 2012
    6,303
    4,019
    My projects all seem to work and my favorite meter, a Fluke 8025A - made in 1983, has not been calibrated since 1985. Seems like an interesting project though.
    Dr.killjoy likes this.
  4. #12
    Nov 30, 2010
    16,665
    7,310
    You must be younger than I. The idea of soldering a dozen SMDs makes my eyes hurt.:(
  5. crutschow
    Mar 14, 2008
    13,475
    3,362
    My multimeters only go to 1.999V on the 2V scale.
    What do yours go to?
    Dr.killjoy and GopherT like this.
  6. RichardO
    May 4, 2013
    1,335
    429
    My meter is even older. A Data Precision 4 1/2 digit one from when 4 1/2 digits was still special. I have thought about doing similar project but cant find a reference that has 4 1/2 digits of absolute accuracy right out of the package. :-( (I realize that my meter is no where near 4 1/2 digits of accuracy but I can dream can't I).
    Mine, too. Maybe 2 each 1.0000 volt references in series? Analog devices has a ADR130. Not as good as the 2.048 volt references, though.
    Another option would be a calibration resister in series with the 2.048 volt output of the reference. Just big enough to divide with the meter's 10 megohm input to give 2.0000 volts. On second thought, that resistor would be huge since it would have to drop the voltage by about 2.4%.
  7. mcgyvr
    Oct 15, 2009
    4,787
    973
    um.. your smartphone is on the fritz.. Or turn the autocorrect back on..
  8. #12
    Nov 30, 2010
    16,665
    7,310
    My Fluke counts to 3200...and sometimes just a tiny bit more.
  9. tcmtech
    Nov 4, 2013
    2,107
    1,747
    I say cut holes in your PCB and recess mount the surface mount stuff down in them that way you will have in hole surface mount. :p
    #12 and Dr.killjoy like this.
  10. GopherT
    Nov 23, 2012
    6,303
    4,019
    I think the OP has a Fluke 87 - they run at 6000 counts in low res and 20000 counts in high res mode.
  11. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    Thanks I have the Fluke 87 series II and every meter I own is autoranging hence it's design but what I will do is try to find a suitable Vref below 2v and build a seperate design if you would like ??
  12. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    Thanks grammer nazi..:p:)
  13. tcmtech
    Nov 4, 2013
    2,107
    1,747
    Well you are now the first to have ever called me that! :eek:
    I've always rather considered myself to be a grammar pollock.:p
    Sinus23 and Dr.killjoy like this.
  14. tcmtech
    Nov 4, 2013
    2,107
    1,747
    So basically all he just needs a 2 volt ~(+-.1 volt) reference. The other two lower sets of numbers is just to make him feel like the money he wasted on the made in china meter was justified.
  15. GopherT
    Nov 23, 2012
    6,303
    4,019
    What made-in-America devices do you use?
  16. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    I choose the voltage because it was the lowest voltage with the best specs I could find .... I have a couple flukes and bought them used and they still work perfectly .. The reason I choose them was because for the price of a quality Chinese unit I could get a used fluke that might save my life or someone else if something where to happen..
    The purpose for the build is so any one can build a quality Vref for say under $10.00..
  17. DickCappels
    Aug 21, 2008
    2,755
    665
    If you can make it all surface mount you will certainly save yourself some trouble drilling holes. If you some of the parts you need to use only come in through-hole packages, you can probably mount them on the surface anyway. You should should not feel shy about using the most practical approach.
    Dr.killjoy and atferrari like this.
  18. tcmtech
    Nov 4, 2013
    2,107
    1,747
    None. I'm not brand or place of origin loyal. I own many devices that come from far off countries that cost way less than what made in America brands charge for similar quality or lack thereof.
    I'm pretty sure all of my multimeters come from somewhere that doesn't tack a 200+ % markup legacy fee on to their products because of what their name once stood for. :p
  19. Lestraveled
    May 19, 2014
    1,957
    1,217
    @Dr.killjoy
    What you are building is called a "transfer Reference". (I have one based on the AD587LQ for 10 volts.) After temperature cycling it for so many times you can send it to a cal lab and they can trim it to your preferred voltage for a pretty cheap price. They send it back to you and you have a great voltage reference to compare your meters to.
    Dr.killjoy and RichardO like this.
  20. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    Sorry for the no updates but I have had work and alot of repairs that needed to be done ..
    I looked in too a Vref below 1.99v and found some ok IC chip but can't match the tolerance of 2.048v IC... So I would just use DickCappels design posted below..
    My only problem right now I am working on is finding the right P-fet to work with 18650 cell ...
    I was looking at the FQPF9P25YDTU but not sure if would work or is there a better choice..
    Thanks for the advice and helps out alot ..
    I am happy with the voltage I choose but will have to check that out..
