1st Order Filter
Discussion in 'General Electronics Chat' started by dmatsuda, Apr 29, 2014.
  1. dmatsuda
    Apr 29, 2014
    Could someone please explain what it would mean to pass data through a 3 second 1st order filter? Any help is appreciated, thanks!
  2. MrChips
    Oct 2, 2009
    12,652
    3,461
    You are not going to get any answers because I doubt that there is anyone that understands the question. You are lacking significant amount of information.
    1) What is the data?
    2) What is the significance of "3 second"?
    3) What type of filter is the "1st order filter", low-pass, high-pass, band-pass, band-stop, notch?
    4) What is the cut-off frequency of the filter?
  3. crutschow
    Mar 14, 2008
    13,523
    3,390
    If by "3 second" you mean a time-constant of 3 seconds then the filter corner frequency would be 0.05Hz. As MrChips noted what that does to the data depends upon the data and the type of 1st order filter it is.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Do you need some introduction to filtering. I can see what I can come up with from the web. For a beginner it can be hard to know what to look for
