What is the application? The usual reason for using a Schottky diode is the lower forward voltage drop. This parameter is a function of load current so be wary of fixating on a single value. A typical Schottky diode should have a Vf of 0.2-0.3V so I'd be careful of the proposed replacement especially at higher current levels.
I just could not find it , do you have any widely available equivalent to it ?The typical Vf of a 1N5408 with 1A current will be around 0.7v, whereas a BYS 045 will have around 0.5v @ 1A. The 1N5408 will dissipate 1.4 times the power of the BYS 045.
Why not just replace them with the original part?
Mouser stocks them:
http://www.mouser.com/ProductDetail...45-E3-TR/?qs=sGAEpiMZZMsYCk4rqFpP/eOGTB7LeFRQ
You don't get the point , i don't have the time to order it online right now , and if i do , i will have to wait 15 days , am looking for another equivalent , not specifically SMD type , just a schottky diode that would do the same job as the original , i cant find any on the net thats why i asked here , maybe some one has experience with this type of diodes .A quick check revealed your diodes as available from Mouser.com for (are you ready for this?) as little as 17 cents each!
I buy my components from a electronics selling store , but the seller doesn't have a big knowledge on components specs , thats why i want to get some information here , and see what diodes would make a close match to the original one , am pretty sure the store will provide at least one of those matchs .If you can't order one, then what type of Schottky diodes do you have available to purchase or use? Where do you buy/get your devices?
Nice answer .The main issue in that application is diode speed.
The IN5408 is hundreds of times too slow, and will cause problems and fry itself. And possibly fry other parts.
Like everyone has said; just order the correct part.
Probably not if its in a SMPSU!Is it possible to use 1N5408 diode instead of this schottky diode BYS 045 :
BYS 045 :
If = 1.5 A
Vrpm = 25v to 45v
Ifsm = 40A
Vf = 0.50 v
Tj max = 150 C
You'll have all the time in the world to sit and twiddle your thumbs after excessively slow rectifiers cause the rest of the circuit to burn up.You don't get the point , i don't have the time to order it online right now , and if i do , i will have to wait 15 days ,.
Then you have a little work cut out for you. Since there are likely many Schottky diodes that would meet you spec, you need to determine all the diodes he has and then look them up to see which may be Schottkys that meet or exceed you requirements.I buy my components from a electronics selling store , but the seller doesn't have a big knowledge on components specs , thats why i want to get some information here , and see what diodes would make a close match to the original one , am pretty sure the store will provide at least one of those matchs .
by Aaron Carman
by Aaron Carman
by Jeff Child
