See attachment for an example of how much the voltage across a Zener changes with current through it. At that low a current you may only get about half the rated voltage. So about 0.5 mA out and only about 1 Volt (?).
Wow... I didn't even know those existed. Kind of expensive, though, at $2.28 a pop.You might consider a constant-current diode.
Current regulator diodes are J-FET's with the gate tied to the source. Because of this the minimum voltage allowed across the "diode" is the gate-source threshold voltage of the FET. The 1ma diode in the link looks like it needs around 3 to 4 volts minimum.You might consider a constant-current diode.
And for that money you get a very inaccurate current. The 1ma diode in the link can vary between 0.88 and 1.32 ma!Wow... I didn't even know those existed. Kind of expensive, though, at $2.28 a pop.
As previously noted, the zener current is too low for the zener to regulate voltage.What are the pitfalls of the 1mA constant current source shown below?
Glad that you did. You just hit a sensitive spot with me.Fair enough. Just thought I'd throw it out.
Don't we all? ... and there are no shortcuts!But that's how we learn
by Jake Hertz
by Don Wilcher
by Duane Benson
