I am working on a circuit and part of the ciruit needs a 1kHz square wave. I had prototyped on a breadboard using the signal from an analog trainer. I want to move the design to a perf board to put the circuit in an enclosure.
I do not want to use a 555 as I already have one on the cirucit for a variable frequency. I can also build using a astable multivibrator with 2 transistors but it requires 2 cap's and 4 resistors and the values have to be calculated for 1kHz signal.
Any other way to generate the signal?
Regards,
Praveen Minumula
Regards,
Praveen Minumula
