1978 Heathkit function generator
Discussion in 'Marketplace' started by someonesdad, May 19, 2011.
Thread Status:
Not open for further replies.
  1. someonesdad
    Thread Starter Senior Member
    Jul 7, 2009
    1,585
    141
    This thing doesn't work. A few years ago I had used the schematic and a DMM to find that it appeared the 15 V regulator chip was bad. A friend sent me a chip, then I stuck the chip and the generator on the shelf and forgot about it, as I have a number of other function generators.
    I just came across this thing and thought I'd replace the regulator chip this afternoon. It still doesn't work, so either my troubleshooting was wrong or there's something else broken.
    I built this thing from a kit in 1978 and used it for 15-20 years. It might still have some life in it, although the attenuation pot is noisy. If one of you folks want it, you can have it for $20 shipped CONUS. Otherwise, I'm going to toss it, as there's nothing really salvageable except the power transformer and power cord.
    Oh, it comes with the instruction manual, which is quite good, as it has the schematic, parts layout on the PC board, and instructions on how to calibrate it with a scope.
    When it worked, it put out sine, square, and triangle waves from 1 Hz to 1 MHz. No DC offset. 50 ohm output.
    If you want it, send me a PM before May 23, as that's garbage day.
  2. loosewire
    Apr 25, 2008
    1,584
    435
    Take a look at the resistors and values,a member was looking for resistors.
    Count how many and some values and post them or show a picture that
    picks up the colors. Is that to much trouble,it would show a new techique.
    If you built it ,it will have some long lead resistors.What do you think.
    P.S. My home town allows the highest per diem.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Resistors are easy. ICs are hard.
  4. someonesdad
    Jul 7, 2009
    1,585
    141
    Sorry, it's not worth much effort. I just thought someone getting into electronics might like a well-documented tool to troubleshoot and get working. The biggest pain for me is having to box it up and drive a number of miles to the Post Office to mail it.
Thread Status:
