1965 GM radio help needed
Discussion in 'General Electronics Chat' started by David F., Nov 20, 2013.
  1. David F.
    Nov 20, 2013
    6
    Don't know if you guys can help me. I have a radio out of a 1965 Corvair and I was trying to test it, either I hooked it up wrong or it is no good. I get a high pitched squeal when I turn it on and try an tune in a station.
    I have it connected to a 8 ohm speaker, with the two green with black stripe wires going to the speaker and the black with yellow stripe going to the hot + battery, with the neg. to the radio chassis.
    I tried finding a 1965 GM radio wiring diagram on the NET, but couldn't locate any.
    If anyone has a diagram or can tell me if this is connected right, I would appreciate it.
    Picture of rear of radio below.
    David
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  3. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    This was a time that the 12v tubes (valves) were coming in just prior to the transistor versions.
    Which version is it? the high voltage tubes had a vibrator.
    One of the weak points around this time was the decoupling caps, the wax coated ones.
    Max.
  4. David F.
    Nov 20, 2013
    6
    Don't know much about radio electronics, I don't see any tubes. Took the cover off and took two pictures, does this help?
    David
  5. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    I guess you rigged up an antenna? Can you hear any stations in the back ground?
    Max.
  6. shteii01
    Feb 19, 2010
    3,500
    511
    Check local library, it might have some books/manuals.
  7. David F.
    Nov 20, 2013
    6
    Yes I have an antenna, no stations, just a varying hi pitch squeal.
    Checked the local library, their wiring diagrams, like the ones on the NET, don't show the radio.
    David
  8. shteii01
    Feb 19, 2010
    3,500
    511
    How many speakers are supposed to be connected to the unit? 2?
  9. gnuuser
    Jan 17, 2013
    13
    you had it hooked up correctly but this is an am radio
    if there are flourescent lights nearby you will get a lot of noise from them.
    but it would usually be a loud hum or buzzing.
    a high pitched noise could be a failed transistor. or a shorted trimmer or tuning capacitor
    this is a transistor radio
  10. David F.
    Nov 20, 2013
    6
    OK, Thanks. I have tested Ford radios in the same location, and they worked OK. There is a neon light, will try the radio outside, when the rain stops.
    David
  11. #12
    Nov 30, 2010
    16,657
    7,303
    AM superhetrodyne with almost 50 years of dirt and humidity in the coils.:(
    Getting these back into serviceable condition is an art unto itself.
    The tricks of this trade are numerous.
    Gotta go with Bertus. You belong on a Vintage Radio site.
  12. David F.
    Nov 20, 2013
    6
    I am going to post there, but it sounds like the radio is bad.
    David
  13. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    I managed a TV & Car Radio service depot for a couple of years back in the 70's and the CR techs would replace the caps, regardless as a matter of course when one came to the bench.
    IIRC that included the electrolytic's.
    Max.
  14. #12
    Nov 30, 2010
    16,657
    7,303
    While you're doing, "as a matter of course", any carbon resistor in the 100k and up range will be a higher value than it was designed for.
  15. David F.
    Nov 20, 2013
    6
    Thanks for the help. I shot the radio with electrical cleaner and got the connections right, and now it works. A Miracle :)
    David
  16. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    That Always helps!!. :cool:
    Max.
