1963 Gas Gauge Project
Discussion in 'The Projects Forum' started by bbowles, Jun 6, 2011.
Thread Status:
Not open for further replies.
  1. bbowles
    Jun 6, 2011
    Hello everyone, I am a bit stuck on a project and need some tips. My skill level is only hobbyist.
    The problem:
    The vehicle has a gas gauge from 1963 that moves based on a coil of wire wrapped around a flexible metal strip. As the coil warms the gauge increases. The gauge registers 0 ohms as full and 70 ohms as empty. A new tank and sending unit was installed at some point in it's history. The new sending unit is 200 ohms full and 60 ohms empty.
    My proposed solution:
    Use ATTiny13 built in ADC to read the sender and PWM to drive an NPN transistor going to the gauge. I've figured out the ATTiny13 well enough to read a potentiometer with the ADC and control an LED based on the ADC reading with the PWM.
    Where I need help:
    The ADC reads the voltage as reference to Vcc (5v), 1024 = 5v and 0=0v. The gauge runs off 5v too. I want to use a voltage divider to read the sending unit's resistance but can't figure out what I need to do to limit the current enough and still have a wide enough range with 60-200ohms.
    I imagine the circuit resembling:
    ??? ohms
    + --/\/\/\(fixed)-------ADC
    _ --/\/\/\(sender)----
    60-200 ohms
    I can't figure out any resistance configuration that gives me more of a range than 30 on the ADC. Am I on the right track or do I need to figure out a different way to measure the voltage coming from the sender to correspond to the resistance?
    Thanks in advance for any help!
  2. #12
    Nov 30, 2010
    16,665
    7,310
    Car projects are forbidden on this site.
  3. bbowles
    Jun 6, 2011
    The forum seemed to remove my leading spaces on the |. It is supposed to be on the ADC side.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Sorry, but our Terms of Service don't allow discussion of that topic -
Thread Status:
