18v transformless supply
Discussion in 'General Electronics Chat' started by guruji, Sep 19, 2008.
Thread Status:
Not open for further replies.
  1. guruji
    Nov 11, 2005
    29
    Hi guys first of all sorry for the poor image cause I don't have an editor.
    How can I modify this circuit from 240v supply to 12v led bulb not 18v?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    That is a very dangerous design. There is no isolation from the mains.
    A transformer will be somewhat more expensive and bulky, but it won't kill you like the circuit you posted very likely will.
  3. cumesoftware
    Apr 27, 2007
    1,330
    11
    Indeed. The phase will surely be present at the output on both terminals. So even if the voltage between them is just 18V, you will get a shock when touching one, if you don't get killed in the meantime.
    Sorry if I'm not optimistic, but the danger is very real. My advice is not to.
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Use a 12V transformer. They are several orders of magnitude less expensive than funerals or hospital visits.
  5. scubasteve_911
    Dec 27, 2007
    1,202
    yeah, totally uncool and unsafe 'design'.. maybe natural selection's final frontier?
  6. guruji
    Nov 11, 2005
    29
    Hi guys thanks for the warnings yes it is dangerous but this is for a led bulb which is going to be sigiled in a holder.It is not going to be used like other transformers.
    Any help please?
    Thanks.
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Sorry, it's just too lethal. Buy a wall wart. Do not fool around with any transformerless power supply.
Thread Status:
