18650 Li-Ion charging circuit
Discussion in 'The Projects Forum' started by doby, Mar 14, 2016.
  1. doby
    Thread Starter Active Member
    Aug 17, 2011
    43
    I have a project that I want to power from 2 18650 cells in series (7.4V)
    The problem is I cant find any prebuilt protection circuits for 2 cells in series that also have micro USB input and LEDs to signify a charging/charged state.
    I don't want to build my own circuit as space is limited and prebuilt circuits offer the smallest size possible in most cases.
    So I've come up with a solution by using 2 TP4056 modules to charge each cell independently and then switching to a 2s PCM to handle the cells in series once charged. Ideally with 2 switched positions, ON(Load) and OFF/Charging.
    What I'm unsure of is how many of the connections I have to switch to do this safely. Obviously their would need to be switch for connecting the cells in series, but what else would need to be switched?
    Or am I going about this the wrong way?
    The attached image is my guess, but could it be done with less switches? I want the switch action to happen all at once so for 3 would need to use a 3PDT switch, all of which are huge and I need something quite small. Suggestions?
  2. Dodgydave
    Jun 22, 2012
    5,166
    775
    You wonf find any usb series chargers because they would need a 10v supply, so if you want to charge them at once, you will need a mains charger, or two usb circuits each separately,
    usb2 wont give more than 500ma, usb3 900ma.
  3. doby
    Aug 17, 2011
    43
    Huh? Phone chargers can supply 2A through a USB connection...
    Anyway, that's beside the point, I'm really looking for help with switch integration.
  4. Dodgydave
    Jun 22, 2012
    5,166
    775
  5. doby
    Aug 17, 2011
    43
    That's a 4s PCM, I only need a 2s and its already in the circuit I attached in the original post. The problem with those is unlike the TP4056, they don't have LED's or a micro USB port.
  6. Dodgydave
    Jun 22, 2012
    5,166
    775
    so you will have to switch the batteries out of circuit to charge, and switch back in to use.or use a 9v supply and bpm
