18650 Ideas about build a DIY power bank to charge my cell phone?
Discussion in 'General Electronics Chat' started by Dr.killjoy, Apr 2, 2016.
  1. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    Over the years I have collected a few 18650 cells and I am trying to find a use for them..I was thinking about build a DIY power bank to charge my cell phone but I am open for ideas here ..
    Jay
  2. InspectorGadget
    Nov 5, 2010
    211
    42
    Whatever you do with it, get a "protection circuit". I put a couple of them in my old NiCd-powered power screwdriver, and got an R/C (radio/control) balanced charger to charge them, but I didn't have a protection circuit. The second or third time I ran it down, the weaker cell stopped recharging. When you have a series battery pack and you run it down to near depletion, the weakest cell will be driven down to zero (and even negatively biased if you run it down far enough). That kills cells like these.
    I went on Amazon and got myself a cute little 2-cell protection circuit PCB assembly. I just got my new cells and still have to wire it up.
    So in general they're a good replacement for NiCd/NiMH in appliances or toys that had multiples of three cells. Three NiCd/NiMH = one LiIon in voltage. So tools that are 3.6V, 7.2V, 10.8V, 14.4V. You get an R/C multi-cell "balance" charging cable like this that will let you charge it with an inexpensive hobby charger and will keep your cells in balance.
  3. Dodgydave
    Jun 22, 2012
    5,141
    767
  4. InspectorGadget
    Nov 5, 2010
    211
    42
    As near as I can tell, Dave, you have one bad (below cutoff threshold, usually 3.0V) cell and the protection circuit is cutting it out so it won't even charge. Best way to charge these is with hobby chargers that charge the cells individually (with a "balance" charge cable). But it necessarily bypasses the protection circuit for charging. Still, with multi-cell Li-Ion/LiPoly packs, it's the best way to charge.
    Dodgydave likes this.
  5. Externet
    Nov 29, 2005
    775
    57
    My electric broom had a series of three NiCd cells. Now has three 18650 in parallel.
    My baby LED flaslights used 3 AAA cells in a holder, now a single 18650. Larger flashlights run on 18650 too.
    My ATV quad had a 12V lead-acid for starting. Now a bunch of 18650's.
    My electric shaver got the transplant too. An intercom too.
    Also my two 12V NiCd drills have now three 18650 in series.
    My electric screwdriver had two NiCd, not anymore.
    My spectrum analyzer had a 3.6V battery for memory backup, now a 18650.
    And I may forget others...
  6. AnasMalas
    Member
    Nov 27, 2015
    66
    10
    if you are into latte making then you can mod the "Latte foamers" (although i personally use em for stirring, but thats just me) you can get one of the 3$ ikea ones and mod it...
    semi related, i modded mine be sawing off most of the battery compartment, soldered on a usb connector at 90 degrees, and just inset the generic power banks to use it. runs great and is much more powerful (5v vs 3v)...
    you could also make some circuits such as LED lights all over you house, get special holders made just for the cells, and just light up some decoration! example if you have a small table in the middle of your living room, you could decorate that!
    just dont forget to use protection. if you dont, then expect to use them for some barbecue! although human meat isnt that appetizing is it :eek:
  7. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    Wait what is the cell capacity per cell again??
  8. Dodgydave
    Jun 22, 2012
    5,141
    767
    9900maH, i can charge them up on my atx psu no problem, but this poxy pcb won't work, i have ordered a different one.
  9. AnasMalas
    Member
    Nov 27, 2015
    66
    10
    IN 18650 SIZE!! oh my... who ever sold them slapped an extra zero at the end it seems man... this size cant hold more than 3200 if even that for the most expensive cell....
    that is surely dodgy, dave!
    Dodgydave and Dr.killjoy like this.
  10. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    Hence my reply ..So pcb might be good and cells bad then..
  11. ScottWang
    Aug 23, 2012
    4,925
    777
  12. Dodgydave
    Jun 22, 2012
    5,141
    767
    Yep 9900mah
  13. ScottWang
    Aug 23, 2012
    4,925
    777
  14. hp1729
    Nov 23, 2015
    2,086
    232
    There is the larger 32650 for more mAh. Usually the charger output is 5 V. The charging chip inside the phone brings it down to the 3.7 V. So you need a circuit to bring the external battery up to 5 V.
  15. AnasMalas
    Member
    Nov 27, 2015
    66
    10
    Now, dodgydave, please now that its working, get a 15 ohm 0.5 watt resistor, put a voltmeter and an ammeter on, put a watch, film the whole thing in 1FPS time laps, and show us that your batteries will put out 0.25 Amps (I=V/R = 3.6/15 = 0.24A) for 9.9/0.25 = 39.6 hours or if it will be just be 3.96 hours... i really want to know because these are so energy dense they could help create a flux capacitor!!
  16. hp1729
    Nov 23, 2015
    2,086
    232
    Interesting! 9900 mAh at what current level I wonder. You wouldn't have a data sheet for the battery would you?
  17. AnasMalas
    Member
    Nov 27, 2015
    66
    10
    I really dont think even 1 micro amp could get that much... but i am not an expert...... niether is whoever sold these...
  18. Dodgydave
    Jun 22, 2012
    5,141
    767
    Dr.killjoy likes this.
  19. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    I wasn't planning on make a battery pack but more or less for ideas for uses on the 18650 cells. A while ago I looked into making a power bank from scratch .. But I got pretty shot down cause the pcb design issues with smps and I am still a noob.. I already have a couple battery packs that use 2 18650 but I wanted something larger and everything of good quality is around $50 more or less and it seem alot IMO. The cheaper units have great and bad reviews but not sure worth the risk and or repair..So I have a bunch of 18650 cells just hanging around.. I am toying with the idea but can't decide to make or not (Oh I have junk phones to test on too lol)??
    Units I was looking at
    http://www.amazon.com/gp/product/B00ZZSA4SA/ref=s9_al_bw_g107_i5
    http://www.amazon.com/gp/product/B00ZZN6J0W/ref=s9_al_bw_g107_i4
    http://www.amazon.com/KMASHI-15000m..._cp_107_1?ie=UTF8&refRID=0R37WE3S7KF9GMBZ1S9J
    @ScottWang
    Thanks and I was checking them out but found it cheaper to buy one with cells installed
    @Dodgydave
    No problem
    Glad you got it fixed
  20. Dodgydave
    Jun 22, 2012
    5,141
    767
    I got mine to work with the new pcb charger, it runs my radio with 3cells at 12.5v, and turns off when the voltage gets to 10.5v.
    I use 9900maH cells, it takes 256ma and lasts about 21hrs. Even tried it without the pcb with just the batteries in series and i get an extra hour discharge down to 7.9v,and they still charge up and work.
