180°C sensor with 2°C sensitivity
Discussion in 'The Projects Forum' started by drago, Feb 23, 2011.
  1. drago
    Aug 12, 2009
    14
    I need to built a circuit similar to this
    http://forum.allaboutcircuits.com/showthread.php?t=43391
    but on higher temperature and much more accurate.
    For me problem is how to start! What sensor to use that is reliable at 180°C for long period of time and accurate.
    Circuit is used in machine for producing PVC tubes in chamber where temperature must be regulated in 2°C with fans and blowers.
    If you guys help me to start and chose a right sensor other part of circuit how to power on the fans is not a problem. Fans which are DC i will use mosfet to power them on and for AC i will use relay.
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
  3. drago
    Aug 12, 2009
    14
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
  5. drago
    Aug 12, 2009
    14
  6. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    Figure 4 at that page will give you an amplified signal:
    The output could be used to feed the circuit from the circut you showed in your first post.
    Bertus
  7. drago
    Aug 12, 2009
    14
    max4237/4237 are high-precision op amps and i can't find them in RS Components store.
    Can you suggest me a alternative that is available in RS?
    Yes!figure 4 is a basic amplifier with added positive feedback through R2. This will add me more precision to drive a comparator
    Bertus you are a hero!
