I have a 10 Hp, 1770 rpm rated motor on an air compressor. The air compressor started sounding different the other day, and seemed to be turning too slow. I measured the motor shaft speed with a stroboscope and it was turning at 1184 rpm. The voltage and amperage on each phase is good and power supply is at 60 Hz. What could my problem be? It is a 600 VAC 3 Ph 60 Hz motor, induction type.
