17.24khz output must be regulated to the vicinity of 60hz
Discussion in 'General Electronics Chat' started by jbdman, Feb 16, 2015.
  1. jbdman
    Feb 16, 2015
    I have a joule thief outputting from around 100v-700v and when it gets a load it is right around the 120 volts. The problem is that when for example i plug in a USB phone charger, it flashes from the high hertz. How would I go about regulating this? Thanks -Josh
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    What are you trying to do?
  3. jbdman
    Feb 16, 2015
    Regulate the 17 khz coming out of a joule theif to around 60 hz
  4. Alec_t
    Sep 17, 2013
    5,979
    1,138
    Can you post a schematic of your Joule thief circuit?
  5. jbdman
    Feb 16, 2015
  6. Alec_t
    Sep 17, 2013
    5,979
    1,138
    There's no way you can convert that circuit to run at 60Hz if it's designed to work at ~17kHz. It's also unlikely that the circuit can provide anywhere near enough continuous power to supply a USB charger.
  7. jbdman
    Feb 16, 2015
    Yeah, the transistor already tried to kill itself on a 23w bulb!
