16F88 RA5, RA6, RA7 problems - PBP
Discussion in 'Embedded Systems and Microcontrollers' started by tracecom, Dec 10, 2013.
  1. tracecom
    Thread Starter AAC Fanatic!
    Apr 16, 2010
    3,878
    1,396
    I am unable to set RA5, RA6, and RA7 as outputs on the 16F88. Although the datasheet doesn't make it perfectly clear, I assume that RA5 can only be an input. But what could be wrong with RA6 and RA7? I don't think it's the code or my wiring because I can successfully use all the other 13 I/Os as outputs. Is there some "trick" to using RA6 and RA7 as outputs in the 16F88?
    Thanks.
  2. MaxHeadRoom
    Jul 18, 2013
    10,833
    2,502
    Did you set the outputs for digital I/O via tha ANSEL reg to turn off the analogue inputs?
    The RA5 is input only.
    Max.
  3. tracecom
    Apr 16, 2010
    3,878
    1,396
    I think so. My initialization section when trying to use RA6 is as follows.
    TRISA = %10111111
    OSCCON = $60
    ANSEL = 0
  4. Markd77
    Sep 7, 2009
    2,803
    594
    Have a look at the config word, oscillator options, because they can stop those pins being normal I/O.
  5. tracecom
    Apr 16, 2010
    3,878
    1,396
    Correct. I just stumbled on the answer.
    #CONFIG
    __config _CONFIG1, _FOSC_INTOSCIO & _WDT_ON & _LVP_OFF & _CP_OFF
    #ENDCONFIG
    Thanks to you and Max.
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Also Tracecom it's good to read the datasheet chapter "I/O ports" and sub chapter "PORTA" as it gives specific details of each port pin, and how that pin can be configured. :)
